[mapguide-trac] #22: Improve AJAX Viewer Load Time
MapGuide Open Source trac_mapguide at osgeo.org
Mon Apr 2 19:58:04 EDT 2007
 Reporter:  robertbray   |         Owner:
     Type:  enhancement  |        Status:  new
 Priority:  medium       |     Milestone:
Component:  General      |       Version:
 Severity:  major        |    Resolution:
 Keywords:               |   External_id:
Comment (by pagameba):
 wow, anonymous sure does a lot of work around here ;)
 One possibility.  Every potential legend graphic has a particular position
 in the LayerDefinition.  You could build the image strip as a single
 vertical (or horizontal) strip one legend graphic wide with every legend
 graphic.  The position of the class in the layer definition would be
 sequential and the legend would just use css to position the image based
 on the sequential number of that class.
 The graphic, and the sequence, would have to be recalculated whenever the
 structure of the layers changes.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/22#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
