[mapguide-trac] #27: Schema does not allow setting resource ID
for referenced content in Image graphic element
trac_mapguide at osgeo.org
Tue Apr 3 07:10:11 EDT 2007
#27: Schema does not allow setting resource ID for referenced content in Image
graphic element
Reporter: waltweltonlair | Owner: waltweltonlair
Type: defect | Status: closed
Priority: high | Milestone: 1.2
Component: Server | Version: 1.2.0
Severity: major | Resolution: fixed
Keywords: | External_id: 924298
Changes (by waltweltonlair):
* status: assigned => closed
* resolution: => fixed
Comment:
The schema has been updated. Also fixed a few other problems:
* In SE_ExpressionBase::!ParseStringExpression we call
FdoExpression::Parse, but the latter will throw an exception if it
doesn'tunderstand the input string. I've wrapped the calls in try-catch
blocks, and if we do catch an exception then we simply set the SE_String's
value to be the input string (with no expression).
* In SE_Renderer::!DrawSymbol it's possible for raster primitives that
the pngPtr member is NULL. Added a check for this so we don't call
!DrawScreenRaster in this case.
* In StylizationEngine::Stylize the resources member of SE_EvalContext
was not being set.
All these things have been fixed by submission
http://trac.osgeo.org/mapguide/changeset/1452.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/27#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
