[mapguide-trac] #31: Fix failed unit tests
MapGuide Open Source trac_mapguide at osgeo.org
Wed Apr 4 15:48:19 EDT 2007
   Reporter:  brucedechant  |       Owner:
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  1.2
  Component:  Server        |     Version:  1.2.0
   Severity:  minor         |    Keywords:
External_id:                |
 There are some failing Geometry and KML unit tests.
 The Geometry failures are due to slight rounding errors between operating
 systems.
 The KML failures are due to the KML test server not always being online
 when the unit tests are run.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/31>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
