[mapguide-trac] #30: Ajax and Dwf viewers do not work under
IIS+PHP configuration
trac_mapguide at osgeo.org
Wed Apr 4 15:49:44 EDT 2007
#30: Ajax and Dwf viewers do not work under IIS+PHP configuration
Reporter: trevorwekel | Owner: trevorwekel
Type: defect | Status: assigned
Priority: high | Milestone: 1.2
Component: AJAX Viewer | Version: 1.2.0
Severity: major | Resolution:
Keywords: | External_id: 923603
Changes (by trevorwekel):
* status: new => assigned
Comment:
This defect was caused by the PHP 5.2.1 upgrade. The isapi_fcgi.dll has a
buffer overrun defect. PHP 5.2.1 uses a larger FastCGI buffer size which
uncovers the bug. The fix is to increase the buffer size in
isapi_fcgi.dll. See discussion on the PHP bug list for more information:
http://bugs.php.net/bug.php?id=37448
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/30#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
