[mapguide-trac] #37: AJAX Viewer: Clear selection does not clear
properties
trac_mapguide at osgeo.org
Thu Apr 5 13:08:09 EDT 2007
#37: AJAX Viewer: Clear selection does not clear properties
Reporter: chrisclaydon | Owner: chrisclaydon
Type: defect | Status: new
Priority: medium | Milestone: 1.2
Component: AJAX Viewer | Version: 1.2.0
Severity: minor | Keywords:
External_id: 898636, 893377 |
If you select a single object in the AJAX viewer, its properties are
displayed in the properties pane.
If you use the context menu "Clear Selection" command, the selection is
cleared, but the properties are still displayed in the properties pane.
The properties should be cleared too.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/37>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
