[mapguide-trac] #39: "thread model is not supported" error when
previewing GDAL based layers
trac_mapguide at osgeo.org
Fri Apr 6 19:31:39 EDT 2007
#39: "thread model is not supported" error when previewing GDAL based layers
Reporter: tomfukushima | Owner: brucedechant
Type: defect | Status: new
Priority: high | Milestone: 1.2
Component: Feature Service | Version: 1.2.0
Severity: major | Resolution:
Keywords: GDAL thread model | External_id:
Comment (by brucedechant):
The minimum thread model supported by the MapGuide server is
FdoThreadCapability_PerConnectionThreaded because
FdoThreadCapability_SingleThreaded impacts the server performance
significantly due to having to block all the server's threads using the
single threaded provider. The current server core is not designed to
restrict this type of provider threading and therefore the minimum
FdoThreadCapability_PerConnectionThreaded is now enforced.
My suggestion is to make the GDAL provider thread safe so that it can work
within a multi-threaded server.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/39#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
