[mapguide-trac] #39: "thread model is not supported" error when
previewing GDAL based layers
trac_mapguide at osgeo.org
Fri Apr 6 22:56:50 EDT 2007
#39: "thread model is not supported" error when previewing GDAL based layers
Reporter: tomfukushima | Owner: brucedechant
Type: defect | Status: new
Priority: high | Milestone: 1.2
Component: Feature Service | Version: 1.2.0
Severity: major | Resolution:
Keywords: GDAL thread model | External_id:
Comment (by brucedechant):
Frank,
The FDO team would be able to best answer your first question.
You are correct Frank as we should have caught this sooner. We are still
learning. :)
By adding a mutex to essential block everything inside the GDAL provider
to simulate a singled threaded provider is not the right solution in order
to be compliant. Ideally, you only want to block when absolutely necessary
and not for everything. This will allow maximum performance and will allow
the server to take full advantage of the provider.
If you have any threading questions I would be more then happy to discuss
them with you via email or phone.
Thanks,
Bruce
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/39#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
