[mapguide-trac] #42: Sheboygan Districts layer is displaced
MapGuide Open Source trac_mapguide at osgeo.org
Tue Apr 10 12:32:53 EDT 2007
 Reporter:  waltweltonlair  |         Owner:
     Type:  defect          |        Status:  new
 Priority:  high            |     Milestone:  1.2
Component:  General         |       Version:  1.2.0
 Severity:  major           |    Resolution:
 Keywords:                  |   External_id:
Comment (by waltweltonlair):
 The problem is definitely the Sheboygan data set itself.  All source data
 in the data set should be using the same coordinate system.  In our case
 though, the VotingDistricts feature source shows "LL84" while all the
 others show some a different one - "WGS84 Lat/Long's, Degre" ...  The WKTs
 for these two are different, as noted above.
 To fix this I think we simply need to republish all the data files for the
 data set using the same coordinate system.  We also need to make sure we
 use the correct one!
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/42#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
