[mapguide-trac] #3: MapTips fail when properties have null values
trac_mapguide at osgeo.org
Tue Apr 10 12:49:26 EDT 2007
Reporter: pagameba | Owner: anonymous
Type: defect | Status: assigned
Priority: medium | Milestone: 1.2
Component: AJAX Viewer | Version: 1.1.0
Severity: major | Resolution:
Keywords: | External_id: 911516
Comment (by traianstanev):
There are a couple of workarounds for this. One is to use empty string in
the data as you mention. Another is to have two identical theme rules,
with one filtering by ISNULL on the property that is NULL. None of these
are optimal solutions.
If we update the expression evaluation to replace null strings by empty
strings, what do you suggest we do for properties which are not strings --
replace NULL integer values by 0? I don't even know if an integer value
can be nullable...
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/3#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
