[mapguide-trac] #3: MapTips fail when properties have null values
trac_mapguide at osgeo.org
Tue Apr 10 21:09:59 EDT 2007
Reporter: pagameba | Owner: anonymous
Type: defect | Status: assigned
Priority: medium | Milestone: 1.2
Component: AJAX Viewer | Version: 1.1.0
Severity: major | Resolution:
Keywords: | External_id: 911516
Comment (by pagameba):
Hi Traian, unfortunately this won't work because the use case I was given
includes several fields, some or all of which may have null values, across
many layers. There are just too many combinations to manage.
I believe the issue is primarily for string fields, but you raise a good
point. Since the intention is to create an output string anyway, perhaps
it is sufficient to put an empty string for all types?
Another option would be to introduce an IFNULL conditional operator of
some kind that would allow the user to provide the default value if the
attribute is null? But empty strings would at least prevent things from
failing.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/3#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
