[mapguide-trac] #66: Map Admin - don't fill in the login password
with php
trac_mapguide at osgeo.org
Tue Apr 17 18:57:47 EDT 2007
#66: Map Admin - don't fill in the login password with php
Reporter: tonyfang | Owner: tonyfang
Type: defect | Status: new
Priority: medium | Milestone: 1.2
Component: Map Admin | Version: 1.2.0
Severity: minor | Keywords:
External_id: 907970 |
If the user fails to login to the Map Admin correctly, the password field
should not get filled with the failed password.
However, this fix only works if you have not enabled saving of passwords
with your browser.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/66>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
