[mapguide-trac] #67: Rotated images do not scale in AJAX Viewer
with new symbolization
trac_mapguide at osgeo.org
Tue Apr 17 20:46:58 EDT 2007
#67: Rotated images do not scale in AJAX Viewer with new symbolization
Reporter: waltweltonlair | Owner: waltweltonlair
Type: defect | Status: new
Priority: high | Milestone: 1.2
Component: Server | Version: 1.2.0
Severity: major | Keywords:
External_id: |
If you create a symbol definition containing a rotated image and set a
scale in the symbol instance, then the image is drawn unscaled in AJAX
Viewer. If you set the image angle to zero then it does scale.
There are some TODO comments in the code (GDRenderer::DrawScreenRaster)
noting that this needs to be implemented.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/67>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
