[mapguide-trac] #82: Connections Pooled Setting Problem in Admin
trac_mapguide at osgeo.org
Tue Apr 24 12:54:35 EDT 2007
Reporter: amorsell at spatialgis.com | Owner:
Type: defect | Status: new
Priority: high | Milestone:
Component: Map Admin | Version:
Severity: major | Keywords:
External_id: |
In MapGuide 1.2.0 Beta 1. On the Configure Services screen in Admin, if
one changes any settings and then submits them, it will result in a
"Feature service data connection pool size is invalid.". It looks like it
is reading the custom pooled settings form field, which by default is 0,
rather than the default pooled setting form field. This is easily
confirmed but putting in a non-zero value in the custom field, submitting
the form, and seeing that the setting has been applied to the default pool
setting instead.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/82>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
