[mapguide-trac] #89: Zoom from Custom Search Command Coordinate
System problem
trac_mapguide at osgeo.org
Mon Apr 30 17:07:54 EDT 2007
#89: Zoom from Custom Search Command Coordinate System problem
Reporter: amorsell at spatialgis.com | Owner:
Type: defect | Status: new
Priority: high | Milestone:
Component: AJAX Viewer | Version: 1.2.0
Severity: critical | Keywords:
External_id: |
If you create a custom Search command in a web layout in studio from a
feature source that has a different coordinate system than the map
definition, then the zoom does not perform a coordinate transformation.
This is easily reproduced using a lat lon feature source in a state plane
or UTM map, for instance, and creating a search to that lat lon feature
source. The coordinates in the status bar of the AJAX viewer after the
zoom will display the lat lon coordinates.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/89>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
