[mapguide-trac] #362: Preview of a connection to a set of tiled
rasters causes an unclassified exception
trac_mapguide at osgeo.org
Wed Dec 5 18:11:12 EST 2007
#362: Preview of a connection to a set of tiled rasters causes an unclassified
exception
Reporter: ronnielouie | Owner: ronnielouie
Type: defect | Status: new
Priority: medium | Milestone: 2.0
Component: Server | Version: 2.0.0
Severity: major | Keywords:
External_id: 1011024 |
1) Create a connection to a folder of tiled Tif files and create a
connection.[[BR]]
2) Set the coordinate system override (as necessary).[[BR]]
3) Create a layer.[[BR]]
4) Add the layer to a map and verify extents are correct.[[BR]]
6) Save and preview the map using the AJAX Viewer[[BR]]
7) Attempt to zoom in using the + on the zoom slider and check the error
logs for an unclassified exception. No image is rendered.[[BR]]
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/362>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
