[mapguide-trac] #6: geometry buffer operation fails on curvepolygon
trac_mapguide at osgeo.org
Tue Feb 27 12:46:31 EST 2007
Reporter: pagameba | Owner:
Type: defect | Status: new
Priority: high | Milestone: 1.2
Component: Feature Service | Version: 1.1.0
Severity: major | Keywords:
External_id: |
I have some data that is correctly rendering as polygons but does not
buffer correctly using the AJAX viewer buffer operation. I have dumped
the WKT of the feature:
CURVEPOLYGON ((-123.94884211782004 49.168238831862574 (LINESTRINGSEGMENT
(-123.94854780008535 49.168268848308159, -123.94825348198435
49.1682988640056, -123.94829573817191 49.168477224793179,
-123.94888439769528 49.168417203908902, -123.94884211782004
49.168238831862574))))
Buffering this geom results in a buffer that appears to be a circle around
one point in the polygon (I didn't check but I'd guess its the first
coordinate).
I'm not sure what component to stick this in. There isn't anything for
the Geometry API so I'm sticking it in the feature service, please
reassign as appropriate.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
