[mapguide-trac] #222: Flyout menu in the toolbar shows the
command name and not the command label
trac_mapguide at osgeo.org
Tue Jul 3 13:03:30 EDT 2007
#222: Flyout menu in the toolbar shows the command name and not the command label
Reporter: brucedechant | Owner:
Type: defect | Status: new
Priority: medium | Milestone: 1.3
Component: AJAX Viewer | Version: 1.2.0
Severity: minor | Resolution:
Keywords: | External_id:
Comment (by brucedechant):
Notes from Måns Beckman:
When I was translating MapGuide into Swedish I found that the flyout menu
in the toolbar shows the command name and not the command label set in
MGS. I found where the error was and downloaded the code from the trac.
What I do is simply correcting
root/trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ so that row 1037
says the same thing as 986, changing cmd.name to item.name. I think the
same change should be applied to row 482 in
root/trunk/MgDev/Web/src/viewerfiles/dwfmappane.templ but I haven't made a
real diff for that.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/222#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
