[mapguide-trac] #172: Bug in Selection polygon from PostGiS
(PostgreSql)
trac_mapguide at osgeo.org
Tue Jun 12 10:27:38 EDT 2007
#172: Bug in Selection polygon from PostGiS (PostgreSql)
Reporter: maciej.skorczewski at procad.pl | Owner:
Type: defect | Status: closed
Priority: high | Milestone:
Component: General | Version: 1.2.0
Severity: major | Resolution: fixed
Keywords: | External_id: 939561
Changes (by traianstanev):
* status: new => closed
* resolution: => fixed
Comment:
I have checked in a temporary fix for this. OGR was assuming a BBOX query
if the intersection polygon is axis aligned. I simply warped the input
rectangle by a tiny bit to make it non-aligned. This is enough to make OGR
do real intersection.
I think OGR should be fixed to only resort to BBOX query in case
SetSpatialFilterRect is called. If SetSpatialFilter is called instead, and
GEOS is available, OGR should not try to be smart about reducing the
accuracy of the query by doing a BBOX check only.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/172#comment:13>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
