[mapguide-trac] #213: Bad labels
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 28 17:40:43 EDT 2007
#213: Bad labels
 Reporter:  jrizzo    |         Owner:
     Type:  defect    |        Status:  new
 Priority:  medium    |     Milestone:  1.2
Component:  General   |       Version:  1.2.0
 Severity:  critical  |    Resolution:
 Keywords:            |   External_id:  945351
Comment (by rexszeto):
 Hi, I've been trying to reproduce this, but have been unsuccessful so far.
 The SDF and Layerdef from the package came with some invalid data (mainly
 caused by the join fields). I've tried adjusting the values and the
 preview in layer def showed the labels are working fine.
 Can you please make the correct changes to the package so we are able to
 load the package and see the problem?
 Some problems I've come across:
 - The SDF feature source gives an error "Resource was not found:
 Library://Langan Floor Plans/Data/Database/Floor Plan
 Database.FeatureSource". I fixed this by changing the source field for the
 Room Join.
 - The secondary class for 'Room\' is not specified due to the incorrect
 source (from above). I re-directed it to the correct database
 (Library://Defect/Floor Plan Database.FeatureSource) and chose
 "Default:Floor" as the secondary class.
 - The columns to match the table + secondary class are missing from both
 Employee\ and Room\. For both joins, I matched up the FloorIds.
 - The layer definition was not able to find the feature source, (Due to
 point 1, see above). I correct it by directing it to a working feature
 source, but however, the feature class and labels were all set to default.
 This was where I tried defining the labels for the "Schema1:Office Data"
 class and they all show up fine.
 If there's anything else missing, please include it in the new mgp.
 Thanks, Rex.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/213#comment:9>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
