[mapguide-trac] #6: geometry buffer operation fails on curvepolygon
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 8 17:13:35 EST 2007
 Reporter:  pagameba         |         Owner:
     Type:  defect           |        Status:  new
 Priority:  high             |     Milestone:  1.2
Component:  Feature Service  |       Version:  1.1.0
 Severity:  major            |    Resolution:
 Keywords:                   |   External_id:  916050
Changes (by tomfukushima):
  * external_id:  => 916050
Comment:
 My bad, I didn't realize that I had to login last time; Trac obviously
 doesn't know everything.
 I've got the file now.  Thanks.
 I found the line segment (it seems to be the top part of two joined line
 segments that are almost vertical) in the SDF file that seems to
 correspond to the geometry above, but putting a 1 meter buffer around it
 works fine.  I have attached a picture of the buffer. What size buffer are
 you creating, this can affects the behavior of the buffer algorithm?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/6#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
