[mapguide-trac] #13: ./build_linux.sh Fdo 2.2.x SVN Errors...
trac_mapguide at osgeo.org
Sun Mar 11 18:38:29 EDT 2007
Reporter: anonymous | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Build System | Version:
Severity: major | Keywords:
External_id: |
config.status: WARNING: Makefile.in seems to ignore the --datarootdir
setting
config.status: WARNING: Fdo/Makefile.in seems to ignore the --datarootdir
setting
config.status: WARNING: Utilities/Makefile.in seems to ignore the
--datarootdir setting
config.status: WARNING: Thirdparty/Makefile.in seems to ignore the
config.status: WARNING: Fdo/Unmanaged/Makefile.in seems to ignore the
config.status: WARNING: Fdo/Unmanaged/Src/Makefile.in seems to ignore the
config.status: WARNING: Fdo/Unmanaged/Src/McToMsf/Makefile.in seems to
ignore the --datarootdir setting
config.status: WARNING: Fdo/Unmanaged/Src/Message/Makefile.in seems to
config.status: WARNING: Fdo/Unmanaged/Src/FileToHdr/Makefile.in seems to
config.status: WARNING: Fdo/Unmanaged/Src/Nls/Makefile.in seems to ignore
config.status: WARNING: Fdo/Unmanaged/Src/Common/Makefile.in seems to
config.status: WARNING: Fdo/Unmanaged/Src/Geometry/Makefile.in seems to
config.status: WARNING: Fdo/Unmanaged/Src/Spatial/Makefile.in seems to
config.status: WARNING: Fdo/Unmanaged/Src/Fdo/Makefile.in seems to ignore
config.status: WARNING: Fdo/Unmanaged/Inc/Makefile.in seems to ignore the
config.status: WARNING: Fdo/Managed/Makefile.in seems to ignore the
config.status: WARNING: Fdo/Install/Makefile.in seems to ignore the
config.status: WARNING: Fdo/Install/XsdInstallPaths/Makefile.in seems to
config.status: WARNING: Fdo/Docs/Makefile.in seems to ignore the
config.status: WARNING: Fdo/Docs/doc_src/Makefile.in seems to ignore the
Fdo/Docs/doc_src/group_and_page_definitions/Makefile.in seems to ignore
config.status: WARNING: Fdo/Docs/doc_src/headers_and_footers/Makefile.in
seems to ignore the --datarootdir setting
config.status: WARNING: Fdo/Docs/XmlSchema/Makefile.in seems to ignore
config.status: WARNING: Fdo/UnitTest/Makefile.in seems to ignore the
config.status: WARNING: Utilities/Common/Makefile.in seems to ignore the
config.status: WARNING: Utilities/TestCommon/Makefile.in seems to ignore
config.status: WARNING: Utilities/SQLiteInterface/Makefile.in seems to
config.status: WARNING: Utilities/OWS/Makefile.in seems to ignore the
config.status: WARNING: Utilities/OWS/Src/Makefile.in seems to ignore the
config.status: WARNING: Utilities/SchemaMgr/Makefile.in seems to ignore
config.status: WARNING: Utilities/SchemaMgr/Inc/Makefile.in seems to
config.status: WARNING: Utilities/SchemaMgr/Nls/Makefile.in seems to
config.status: WARNING: Utilities/SchemaMgr/Src/Makefile.in seems to
config.status: WARNING: Utilities/SchemaMgr/Src/Sm/Makefile.in seems to
config.status: WARNING: Utilities/SchemaMgr/Src/Sm/Lp/Makefile.in seems
config.status: WARNING: Utilities/SchemaMgr/Src/Sm/Ov/Makefile.in seems
config.status: WARNING: Utilities/SchemaMgr/Src/Sm/Ph/Makefile.in seems
config.status: WARNING: Utilities/SchemaMgr/Src/Sm/Ph/Cfg/Makefile.in
config.status: WARNING: Utilities/SchemaMgr/Src/Sm/Ph/Mt/Makefile.in
config.status: WARNING: Utilities/SchemaMgr/Src/Sm/Ph/Rb/Makefile.in
config.status: WARNING: Utilities/SchemaMgr/Src/Sm/Ph/Rd/Makefile.in
../../Inc/Common/NamedCollection.h: In member function 'virtual OBJ*
FdoNamedCollection<OBJ, EXC>::FindItem(const wchar_t*) const':
../../Inc/Common/NamedCollection.h:112: error: there are no arguments to
'GetCount' that depend on a template parameter, so a declaration of
'GetCount' must be available
../../Inc/Common/NamedCollection.h:112: error: (if you use '-fpermissive',
G++ will accept your code, but allowing the use of an undeclared name is
deprecated)
make[4]: *** [ArrayHelper.lo] Error 1
make[3]: *** [all-recursive] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
deprecated)
make[3]: *** [install-recursive] Error 1
make[2]: *** [install-recursive] Error 1
make[1]: *** [install-recursive] Error 1
make: *** [install-recursive] Error 1
/home/OpenSource_FDO/Fdo/Unmanaged/Inc/Common/NamedCollection.h: In member
function 'virtual OBJ* FdoNamedCollection<OBJ, EXC>::FindItem(const
wchar_t*) const':
/home/OpenSource_FDO/Fdo/Unmanaged/Inc/Common/NamedCollection.h:112:
error: there are no arguments to 'GetCount' that depend on a template
parameter, so a declaration of 'GetCount' must be available
error: (if you use '-fpermissive', G++ will accept your code, but allowing
the use of an undeclared name is deprecated)
make[1]: *** [FdoCommonNlsUtil.lo] Error 1
wchar_t*) const':
setting
config.status: WARNING: Inc/Makefile.in seems to ignore the --datarootdir
setting
config.status: WARNING: Src/Makefile.in seems to ignore the --datarootdir
setting
config.status: WARNING: Src/Message/Makefile.in seems to ignore the
config.status: WARNING: Src/ShpRead/Makefile.in seems to ignore the
config.status: WARNING: Src/ShpSpatialIndex/Makefile.in seems to ignore
config.status: WARNING: Src/Overrides/Makefile.in seems to ignore the
config.status: WARNING: Src/Provider/Makefile.in seems to ignore the
config.status: WARNING: Src/UnitTest/Makefile.in seems to ignore the
config.status: WARNING: Docs/Makefile.in seems to ignore the
config.status: WARNING: Docs/doc_src/Makefile.in seems to ignore the
Docs/doc_src/group_and_page_definitions/Makefile.in seems to ignore the
config.status: WARNING: Docs/doc_src/headers_and_footers/Makefile.in
wchar_t*) const':
make[2]: *** [DoublePoint.lo] Error 1
wchar_t*) const':
setting
setting
setting
config.status: WARNING: Src/Utils/Makefile.in seems to ignore the
wchar_t*) const':
make[2]: *** [StringValue.lo] Error 1
wchar_t*) const':
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/13>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
