[mapguide-trac] #17: AJAX viewer and IE - Images in tooltip
trac_mapguide at osgeo.org
Tue Mar 13 12:52:28 EDT 2007
Reporter: Andy Morsell | Owner:
Type: defect | Status: new
Priority: high | Milestone:
Component: AJAX Viewer | Version:
Severity: critical | Keywords:
External_id: |
When images are referenced in the tooltip for a layer, the AJAX viewer
with Internet Explorer can yield some very odd results. If it takes too
long for the image to be returned, say more than 4 or 5 seconds, it's like
it tries to call the image again and then this causes a loop which makes
the tooltip to appear to blink. For an example that I just ran into, see
http://mapguide.spatialgis.com/mapguide/spokanemaps/ and turn on the DOT
Cameras layer. When you float your mouse over one of the camera symbols,
a DOT traffic camera image should appear, but often times results in the
above behavior. This works just fine in Firefox.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/17>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
