[mapguide-trac] #97: Webstudio Fails on Localhost connection
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 3 21:41:32 EDT 2007
   Reporter:  zspitzer    |       Owner:
       Type:  defect      |      Status:  new
   Priority:  high        |   Milestone:  1.2
  Component:  Web Studio  |     Version:  1.2.0
   Severity:  major       |    Keywords:
External_id:              |
 I have a vanilla install of mapguide 1.20 beta 1 (bundled php), however, i
 can't connect to the mapguide server via webstudio. the site Explorer
 always fails with a time out on fsockopen in the redirect.php whilst
 trying to connect to the mapguide server. Even with my firewall disabled.
 I am on xp sp2
 After some playing around i found that if i change the config.xml to use
 the 127.0.0.1 ip address instead of localhost i can successfully connect
 to the mapguide server and see the site explorer.
 When i do a ping localhost, it resolves to ::F: which is IPv6
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/97>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
