[mapguide-trac] #102: Java API does not build against JNI
headers for installed JDK
trac_mapguide at osgeo.org
Mon May 7 19:47:23 EDT 2007
#102: Java API does not build against JNI headers for installed JDK
Reporter: trevorwekel | Owner: trevorwekel
Type: defect | Status: assigned
Priority: medium | Milestone: 1.2
Component: Web API | Version: 1.2.0
Severity: major | Resolution:
Keywords: | External_id: 933120
Comment (by trevorwekel):
Further investigation has shown that the build setup requires hard coded
paths in Visual Studio 2005 for both the Java jni include files and the
Java binaries. This is completely different than the Linux build which
simply uses JAVA_HOME.
I have switched the Visual Studio build to also use JAVA_HOME. It is a
cleaner solution and consistent with the Linux build procedure.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/102#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
