[mapguide-trac] #113: MySQL: PHP Fatal error previewing feature source geometry when coordinate system is not read
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 10 14:07:44 EDT 2007
system is not read
   Reporter:  rexszeto  |       Owner:  rexszeto
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:  1.2
  Component:  General   |     Version:  1.2.0
   Severity:  critical  |    Keywords:
External_id:  932977    |
 This error is caused from the feature source's extent being null. A better
 error handler should be implemented.
 1. Create a feature source who's extent is empty
 2. Click on View Feature to preview the geometry
 The following error will occur:
 "PHP Fatal error: Call to a member function GetCoordinates() on a non-
 object in C:\Program
 Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\schemareport\showgeom.php
 on line 93 X-Powered-By: PHP/5.2.1 Content-type: text/html"
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/113>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
