[mapguide-trac] #119: AJAX Viewer: Digitizing Polygon in Safari
blocked by context menu in mapframe
trac_mapguide at osgeo.org
Fri May 11 13:38:10 EDT 2007
#119: AJAX Viewer: Digitizing Polygon in Safari blocked by context menu in
mapframe
Reporter: chrisclaydon | Owner: chrisclaydon
Type: defect | Status: new
Priority: medium | Milestone: 1.2
Component: General | Version: 1.2.0
Severity: major | Keywords:
External_id: 884597 |
1. Setup dotnetviewersample, make sure ajaxviewersample.aspx can run
successfully.
2. Download !SafariDigitize.aspx from Attachments to dotnetsample
application.
3. Configure !MapGuide studio, add commands pointing to
!SafariDigitize.aspx.
4. Open ajaxviewsample.aspx in Safari, choose the page
!SafariDigitize.aspx from task list.
5. Click button "Digitize Linestring", then digitize on the map.
6. After you press ctrl, and click the final point on the map, the context
menu prompt.
Expect:
the context menu should not prompt in the process of digitize.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/119>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
