[mapguide-trac] #127: Fix grid layer schema inconsistencies
trac_mapguide at osgeo.org
Tue May 15 13:26:52 EDT 2007
Reporter: waltweltonlair | Owner: waltweltonlair
Type: defect | Status: new
Priority: high | Milestone: 1.2
Component: General | Version: 1.2.0
Severity: major | Keywords:
External_id: 935553 |
The LDF schema spells the Hillshade tag with a small s, while the
!MdfModel and Parser use capital S. This means that any DEM layer written
by the parser will fail to validate. Since Map 2007 and 2008 already save
!GridLayerDefinitions using the parser we need to update the schema to
match the parser.
The schema also defines a Scale element on !GridSurfaceStylizationType,
but the parser saves it as !ScaleFactor. Once again the schema needs to
be fixed.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/127>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
