[mapguide-trac] #147: MapGuide 1.2.0Beta2 FAILS to Compile on
RedHat FC6, issue with atomic.h or iatomic.h
trac_mapguide at osgeo.org
Fri May 18 18:07:51 EDT 2007
#147: MapGuide 1.2.0Beta2 FAILS to Compile on RedHat FC6, issue with atomic.h or
iatomic.h
Reporter: Ticket#137creator | Owner:
Type: defect | Status: new
Priority: high | Milestone: 1.2
Component: Server | Version: 1.2.0
Severity: major | Keywords: fails, error, compile error, build error, atomic.h, iatomic.h, missing header, Core.cpp
External_id: |
You can not build MapGuide 1.2.0Beta2 on RedHat FedoraCore6, from what
I've read, atomic.h or iatomic.h were taken out of the kernel source in
FC6 for some reason... here's error code (I even tried to grab the
atomic.h files from previous kernel source code, but still got the same
error, I think the configure script needs to find it somewhere and
particular version of it? anyway here's the error:
mkdir .libs
g++ -DHAVE_CONFIG_H -I../.. -g0 -O2 -pipe -Wall -Wno-long-long -Wnon-
virtual-dtor -Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes
-fforce-addr -finline-functions -ffast-math -fno-strict-aliasing -MT
Core.lo -MD -MP -MF .deps/Core.Tpo -c Core.cpp -fPIC -DPIC -o
.libs/Core.o
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
Ada/C/ObjC but not for C++
Core.cpp:79:2: error: #error Missing header file - cannot continue
Core.cpp: In function 'int DWFCore::AtomicIncrement(volatile int*)':
Core.cpp:101: error: 'atomic_t' was not declared in this scope
Core.cpp:101: error: expected `;' before 'tValue'
Core.cpp:102: error: 'tValue' was not declared in this scope
Core.cpp:102: error: 'atomic_set' was not declared in this scope
Core.cpp:107: error: invalid lvalue in asm statement
Core.cpp:109: error: 'atomic_read' was not declared in this scope
Core.cpp:107: error: invalid lvalue in asm output 0
Core.cpp:107: error: memory input 1 is not directly addressable
Core.cpp: In function 'int DWFCore::AtomicDecrement(volatile int*)':
Core.cpp:118: error: 'atomic_t' was not declared in this scope
Core.cpp:118: error: expected `;' before 'tValue'
Core.cpp:119: error: 'tValue' was not declared in this scope
Core.cpp:119: error: 'atomic_set' was not declared in this scope
Core.cpp:124: error: invalid lvalue in asm statement
Core.cpp:126: error: 'atomic_read' was not declared in this scope
Core.cpp:124: error: invalid lvalue in asm output 0
Core.cpp:124: error: memory input 1 is not directly addressable
make[2]: *** [Core.lo] Error 1
make[2]: Leaving directory
`/root/mapguide-1.2.0/Oem/DWFTK7.1/develop/global/src/dwfcore/x86'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
`/root/mapguide-1.2.0/Oem/DWFTK7.1/develop/global/src/dwfcore'
make: *** [all] Error 2
DWFCORE 1.0: Error build failed (0).................
[root at localhost mapguide-1.2.0]#
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/147>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
