[mapguide-trac] #182: Mapguide can't insert features into some SDFs
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 30 05:45:24 EDT 2007
 Reporter:  Nakagawa         |         Owner:
     Type:  defect           |        Status:  closed
 Priority:  medium           |     Milestone:
Component:  Feature Service  |       Version:
 Severity:  major            |    Resolution:  invalid
 Keywords:                   |   External_id:
Changes (by Nakagawa):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 I've found that's the Studio's bug.
 Test2.sdf contains no features. It's identity property
 "Autogenerated_SDF_ID" is set to be autogenerated and read-only (see
 attached "original.jpg").
 When it's loaded via Sutdio to e.g.
 "Library://Samples/Data/Test2.FeatureSource", autogenerated and read-only
 attributes are lost (see attached "loaded.jpg").
 When it comes to Test.sdf, loading works. Test.sdf has 3 features.
 I'm sorry.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/182#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
