[mapguide-trac] #175: Unmanaged SHP File Locations Performance
Issues as More Files get Added
trac_mapguide at osgeo.org
Wed May 30 15:45:02 EDT 2007
#175: Unmanaged SHP File Locations Performance Issues as More Files get Added
Reporter: cgountanis | Owner:
Type: defect | Status: new
Priority: high | Milestone: 1.2
Component: Server | Version: 1.2.0
Severity: major | Resolution:
Keywords: fdo,mapguide 1.2 beta 2, shp, dbf | External_id:
Comment (by tomfukushima):
Hi Chris, open source projects do not expect the community to build and
debug into the code, however if you could do this that would be great.
Typically, what open source projects expect from the community is help in
debugging and pinpointing a problem. I am not a QA person, so I'm not
sure exactly what strategies are best here. But helping us find the
problem by figuring out what combination of SHP files cause the problem,
whether connection pooling makes a difference or not, etc. All of this
could help us pinpoint and reproduce the problem.
To get Autodesk involved, I suggest you use your MGE subscription and
contact Autodesk directly.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/175#comment:9>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
