[mapguide-trac] #291: Symbolization: Fix various problems in the stylization code
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 5 12:25:08 EST 2007
 Reporter:  waltweltonlair  |         Owner:  waltweltonlair
     Type:  defect          |        Status:  assigned
 Priority:  high            |     Milestone:  2.0
Component:  Server          |       Version:
 Severity:  major           |    Resolution:
 Keywords:                  |   External_id:
Comment (by waltweltonlair):
 Any closed Path graphic element in a symbol was always drawing as a
 polygon, while any unclosed Path graphic element was always drawing as a
 polyline. This was regardless of any fill or line color settings defined
 on the Path element. I've fixed this. The code now checks the
 SE_RenderPrimitive type (in this case polygon or polyline) to determine
 what geometry type to set.
 Fixed an arc tolerance bug with DWF Viewer. The tolerance was being set
 way too low, resulting in far too many tessellated segments. Logical units
 were being misinterpreted as pixels.
 http://trac.osgeo.org/mapguide/changeset/2334
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/291#comment:9>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
