[mapguide-trac] #303: Long tooltips truncated depending on feature location
MapGuide Open Source trac_mapguide at osgeo.org
Wed Nov 7 15:43:34 EST 2007
   Reporter:  amorsell     |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:
  Component:  AJAX Viewer  |     Version:  1.2.0
   Severity:  minor        |    Keywords:
External_id:               |
 Tooltip rectification does not always work correctly when floating over
 objects closer to the edges or the map display.  The problem varies based
 on whether using IE or Firefox.  IE behaves fine when floating over
 objects near the top, left, or right.  In this case, it automatically
 positions the popup properly so the whole tooltip is displayed.  But, at
 the bottom, the tooltip popup is truncated at the bottom.   Firefox
 behaves the same way, but has other problems with objects on the right:
 long tooltip strings may be truncated whereas IE will wrap them.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/303>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
