[mapguide-trac] #291: Symbolization: Fix various problems in the stylization code
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 12 16:21:16 EST 2007
 Reporter:  waltweltonlair  |         Owner:  waltweltonlair
     Type:  defect          |        Status:  assigned
 Priority:  high            |     Milestone:  2.0
Component:  Server          |       Version:
 Severity:  major           |    Resolution:
 Keywords:                  |   External_id:
Comment (by waltweltonlair):
 Limit line weight during stylization.  We now check the line weight when
 processing the Path and !DefaultPath elements.  The stylization and
 rendering code isn't always happy when you give it huge values (e.g.
 100000000) for the weight.  The weight - as measured in mm device space -
 is now limited to 1000 mm.  Can anyone think of a use case for rendering
 using a line weight greater than one meter (the size of the output device
 would need to at least be one meter)?
 http://trac.osgeo.org/mapguide/changeset/2413
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/291#comment:15>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
