[mapguide-trac] #315: AGG: Rendering glitch and error
trac_mapguide at osgeo.org
Mon Nov 19 18:55:58 EST 2007
Reporter: jbirch | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Rendering Service | Version:
Severity: major | Keywords: AGG, zinger
External_id: |
I'm seeing some interesting glitches (see attached image for example) with
the new AGG renderer in 2.0. I've tested the same map with GD turned on,
and am not seeing the same.
I am not 100% sure if this is related, but it is accompanied by the
following error messages in the logs (which don't show up with GD turned
on).
<2007-11-19T15:33:34> Administrator
Error: Failed to stylize layer: RoadBuffer
An unclassified exception occurred.
StackTrace:
- MgMappingUtil.StylizeLayers line 759 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_10.7\mgdev\server\src\services\mapping\MappingUtil.cpp
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/315>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
