[mapguide-trac] #318: Stream IO exception : "TCP/IP protocol is
mismatched between the Server and Web Extensions"
trac_mapguide at osgeo.org
Tue Nov 20 17:03:27 EST 2007
#318: Stream IO exception : "TCP/IP protocol is mismatched between the Server and
Web Extensions"
Reporter: fvanderbiest | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: General | Version: 1.2.0
Severity: major | Keywords: exception TCP/IP
External_id: |
On Ubuntu Linux 7.04 (actually a chroot), the Mg server sometimes
outputs this kind of message (while using ajaxtiledviewersample.php) :
(6311|2448243600) A stream IO exception occurred.
The TCP/IP protocol is mismatched between the Server and Web Extensions.
Please install the same version of Server and Web Extensions.
Exception occurred in method MgStreamParser.ParseStreamHeader at line 91
in file System/StreamParser.cpp
Yet, it does not seem to have any visible consequence, from a user point
of view.
Mg was built from svn rev 2448.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/318>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
