[mapguide-trac] #320: Fusion: Bounding box of Sheboygan Dataset is
too small
trac_mapguide at osgeo.org
Tue Nov 20 18:16:27 EST 2007
#320: Fusion: Bounding box of Sheboygan Dataset is too small
Reporter: jng | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: General | Version:
Severity: major | Keywords: fusion
External_id: |
Originally I was going to file this as "Pan tool/widget" only pans
vertically, but after some more playing around with the fusion templates,
it seems to be more of a (bounding box/map extents) issue, as zooming in
closer, the pan tool/widget works as expected.
This could also explain #319 as I am assuming the initial view is governed
by the extents of the map
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/320>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
