[mapguide-trac] #322: Fusion: ApplicationDefinition.xml files for
each template refers to a non-existent map (SheboyganOverview)
trac_mapguide at osgeo.org
Tue Nov 20 18:31:55 EST 2007
#322: Fusion: ApplicationDefinition.xml files for each template refers to a non-
Reporter: jng | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Samples | Version:
Severity: minor | Keywords:
External_id: |
If you load the templates using the ApplicationDefinition.xml file on that
folder, fusion will complain about a map called SheboyganOverview that
does not actually exist.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/322>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
