[mapguide-trac] #324: Fusion: status bar layout/css bugs.
MapGuide Open Source trac_mapguide at osgeo.org
Wed Nov 21 22:02:45 EST 2007
 Reporter:  jng      |         Owner:  pagameba
     Type:  defect   |        Status:  new
 Priority:  medium   |     Milestone:  2.0
Component:  General  |       Version:
 Severity:  major    |    Resolution:
 Keywords:  fusion   |   External_id:
Changes (by pagameba):
  * owner:  => pagameba
 * cc: madair at dmsolutions.ca (added)
Comment:
 * status bar is being redone in all the templates to be a container.
  * The coordinate tracking widget has a bug with the initial load of the
 application, if you change units it will display the correct coordinates
 in the appropriate units (although you can't choose decimal degrees, so
 its kinda useless right now).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/324#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
