[mapguide-trac] #329: Fusion: ApplicationDefinition resources do
not load if its resource id has spaces.
trac_mapguide at osgeo.org
Thu Nov 22 19:43:51 EST 2007
#329: Fusion: ApplicationDefinition resources do not load if its resource id has
spaces.
Reporter: jng | Owner:
Type: defect | Status: new
Priority: medium | Milestone: 2.0
Component: General | Version:
Severity: major | Keywords: fusion applicationdefinition
External_id: |
When you create a new ApplicationDefinition (by hand or with Studio 2009
beta) it will fail on an epic level if any of the following are true:
- The name of the ApplicationDefinition has spaces.
- Any folders or parent folders of that ApplicationDefinition has spaces.
You will get the following effect on the following templates when you load
them:
Slate: Error message: Fusion.getWidgetById("Navigator") has no properties
TurquoiseYellow: Same as slate
Maroon: Base layout loads, but all maps and containers are blank
Aqua: Same as maroon.
LimeGold: Same as maroon.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/329>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
