[mapguide-trac] #330: Fusion: Task Pane flyout is cut off by its parent container
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 22 19:57:27 EST 2007
   Reporter:  jng      |       Owner:
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  2.0
  Component:  General  |     Version:
   Severity:  major    |    Keywords:  fusion
External_id:           |
 When you expand the Task List in the task pane, the menu items are cut off
 by its parent container.
 Perhaps, the task list should be right aligned (not the items, but the
 menu that flys out)
 See attached image
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/330>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
