[mapguide-trac] #332: Fusion: Buffer tool in Aqua Template should open the task pane.
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 22 20:17:53 EST 2007
   Reporter:  jng      |       Owner:
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  2.0
  Component:  General  |     Version:
   Severity:  minor    |    Keywords:  fusion buffer aqua
External_id:           |
 When you load an ApplicationDefinition based on the Aqua template, if you
 select the buffer tool, the task pane that contains the buffer user
 interface does not show if the task pane is not already showing.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/332>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
