[mapguide-trac] #333: Fusion: Select polygon tool/widget does not tell you how to abort/finish the process
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 22 23:26:01 EST 2007
the process
   Reporter:  jng     |       Owner:
       Type:  defect  |      Status:  new
   Priority:  medium  |   Milestone:  2.0
  Component:  Fusion  |     Version:  2.0.0
   Severity:  minor   |    Keywords:  fusion
External_id:          |
 The Select Polygon tool/widget shares the same "problem" as the Measure
 tool/widget.
 It starts, but doesn't tell you how to stop or cancel it when you are
 done.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/333>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
