[mapguide-trac] #326: Districts layer of Sheboygan dataset does
not show its feature labels.
trac_mapguide at osgeo.org
Thu Nov 22 23:42:21 EST 2007
#326: Districts layer of Sheboygan dataset does not show its feature labels.
Reporter: jng | Owner:
Type: defect | Status: new
Priority: medium | Milestone: 2.0
Component: Samples | Version:
Severity: major | Resolution:
Keywords: sheboygan | External_id:
Comment (by tomfukushima):
This is a temporary problem in that numeric values are not being converted
to strings by the new expression engine.
If you change the expression for the label from
concat('District ', Autogenerated_SDF_ID)
to
concat('District ', ToString ( Autogenerated_SDF_ID ) )
The labels will start to show up. We are working on getting things back
to an automatic conversion so that layers do not need to be reauthored.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/326#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
