[mapguide-trac] #334: Fusion: Select Radius tool should provide
visual cues and usage hints.
trac_mapguide at osgeo.org
Fri Nov 23 03:27:00 EST 2007
#334: Fusion: Select Radius tool should provide visual cues and usage hints.
Reporter: jng | Owner:
Type: enhancement | Status: new
Priority: medium | Milestone: 2.0
Component: Fusion | Version: 2.0.0
Severity: major | Keywords:
External_id: |
The "Select Radius" tool provides no visual cue (like the circle digitizer
in the AJAX viewer), which makes it difficult to determine what you are
actually going to select.
Also the tool suffers from the same "problem" as the Measure and "Select
Polygon" tools. There are no hints on how to use it.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/334>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
