[mapguide-trac] #347: Building cgiagent fails because of "missing"
liblib_json.so
trac_mapguide at osgeo.org
Tue Nov 27 18:58:46 EST 2007
#347: Building cgiagent fails because of "missing" liblib_json.so
Reporter: jbirch | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Build System | Version: 2.0.0
Severity: major | Keywords:
External_id: |
I'm trying to build !MapGuide (r2519) on Ubuntu 7.10.
Everything goes according to plan until I get to the final make. At this
point I get an error about a missing liblib_json.so, even though it exists
at:
administrator at vm-mapguide-ubuntu:~/mgsvn$ find . -name "*lib_json.so*"
./Oem/jsoncpp/buildscons/linux-gcc/src/lib_json/liblib_json.so
./Oem/jsoncpp/lib/liblib_json.so
Is it possible that there's a reference to the jsoncpp lib missing?
Here's the error message that I get:
Making all in CgiAgent
make[3]: Entering directory `/home/administrator/mgsvn/Web/src/CgiAgent'
if g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
-DPACKAGE_VERSION=\"2.0.0\" -DPACKAGE_STRING=\"mapguide\ 2.0.0\"
-DPACKAGE_BUGREPORT=\"http://mapguide.osgeo.org\" -DPACKAGE=\"mapguide\"
-DVERSION=\"2.0.0\" -DPACKAGE=\"mapguide\" -DVERSION=\"2.0.0\"
-DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1
-DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
-DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1
-DSTDC_HEADERS=1 -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1 -DHAVE_NETDB_H=1
-DHAVE_NETINET_IN_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_SOCKET_H=1
-DHAVE_GETHOSTBYNAME=1 -DHAVE_SOCKET=1 -DHAVE_HTONS=1 -DHAVE_CONNECT=1
-DHAVE_SHUTDOWN=1 -I. -I. -I../../../Common/Foundation
-I../../../Common/Geometry -I../../../Common/PlatformBase
-I../../../Common/MapGuideCommon -I../../../Common/MdfModel
-I../../../Oem/ACE/ACE_wrappers -I../HttpHandler -I../WebSupport
-I../MapAgentCommon -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-
atexit -fexceptions -MT MapAgentGetParser.o -MD -MP -MF
".deps/MapAgentGetParser.Tpo" -c -o MapAgentGetParser.o `test -f
'../MapAgentCommon/MapAgentGetParser.cpp' || echo
'./'`../MapAgentCommon/MapAgentGetParser.cpp; \
then mv -f ".deps/MapAgentGetParser.Tpo"
".deps/MapAgentGetParser.Po"; else rm -f ".deps/MapAgentGetParser.Tpo";
exit 1; fi
`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.
atexit -fexceptions -MT CgiPostParser.o -MD -MP -MF
".deps/CgiPostParser.Tpo" -c -o CgiPostParser.o CgiPostParser.cpp; \
then mv -f ".deps/CgiPostParser.Tpo" ".deps/CgiPostParser.Po";
else rm -f ".deps/CgiPostParser.Tpo"; exit 1; fi
atexit -fexceptions -MT CgiResponseHandler.o -MD -MP -MF
".deps/CgiResponseHandler.Tpo" -c -o CgiResponseHandler.o
CgiResponseHandler.cpp; \
then mv -f ".deps/CgiResponseHandler.Tpo"
".deps/CgiResponseHandler.Po"; else rm -f ".deps/CgiResponseHandler.Tpo";
exit 1; fi
atexit -fexceptions -MT MapAgentStrings.o -MD -MP -MF
".deps/MapAgentStrings.Tpo" -c -o MapAgentStrings.o `test -f
'../MapAgentCommon/MapAgentStrings.cpp' || echo
'./'`../MapAgentCommon/MapAgentStrings.cpp; \
then mv -f ".deps/MapAgentStrings.Tpo" ".deps/MapAgentStrings.Po";
else rm -f ".deps/MapAgentStrings.Tpo"; exit 1; fi
atexit -fexceptions -MT EchoTest.o -MD -MP -MF ".deps/EchoTest.Tpo" -c -o
EchoTest.o EchoTest.cpp; \
then mv -f ".deps/EchoTest.Tpo" ".deps/EchoTest.Po"; else rm -f
".deps/EchoTest.Tpo"; exit 1; fi
atexit -fexceptions -MT CgiAgent.o -MD -MP -MF ".deps/CgiAgent.Tpo" -c -o
CgiAgent.o CgiAgent.cpp; \
then mv -f ".deps/CgiAgent.Tpo" ".deps/CgiAgent.Po"; else rm -f
".deps/CgiAgent.Tpo"; exit 1; fi
atexit -fexceptions -MT InitializeWebTier.o -MD -MP -MF
".deps/InitializeWebTier.Tpo" -c -o InitializeWebTier.o `test -f
'../WebSupport/InitializeWebTier.cpp' || echo
'./'`../WebSupport/InitializeWebTier.cpp; \
then mv -f ".deps/InitializeWebTier.Tpo"
".deps/InitializeWebTier.Po"; else rm -f ".deps/InitializeWebTier.Tpo";
exit 1; fi
/bin/sh ../../../libtool --tag=CXX --mode=link g++ -O2 -g -pipe
-march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions -o mapagent
-version-info 7:0:0 -L../../../Oem/ACE/ACE_wrappers/ace
-L../../../Oem/dbxml-2.3.10/install/lib -L../../../Common/CoordinateSystem
-L../../../Common/MdfModel -L../../../Common/MdfParser
-L../../../Common/Foundation -L../../../Common/Geometry
-L../../../Common/PlatformBase -L../../../Common/MapGuideCommon
-L../HttpHandler MapAgentGetParser.o CgiPostParser.o CgiResponseHandler.o
MapAgentStrings.o EchoTest.o CgiAgent.o InitializeWebTier.o -lACE
-lxerces-c -lMgFoundation -lMgGeometry -lMgPlatformBase -lMgMdfModel
-lMgMdfParser -lMgHttpHandler
mkdir .libs
libtool: link: warning: `-version-info' is ignored for programs
g++ -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions
-o .libs/mapagent MapAgentGetParser.o CgiPostParser.o CgiResponseHandler.o
-L/home/administrator/mgsvn/Oem/ACE/ACE_wrappers/ace
-L/home/administrator/mgsvn/Oem/dbxml-2.3.10/install/lib
-L/home/administrator/mgsvn/Common/CoordinateSystem
-L/home/administrator/mgsvn/Common/MdfModel
-L/home/administrator/mgsvn/Common/MdfParser
-L/home/administrator/mgsvn/Common/Foundation
-L/home/administrator/mgsvn/Common/Geometry
-L/home/administrator/mgsvn/Common/PlatformBase
-L/home/administrator/mgsvn/Common/MapGuideCommon
-L/home/administrator/mgsvn/Web/src/HttpHandler -lACE -lxerces-c
/home/administrator/mgsvn/Common/Foundation/.libs/libMgFoundation.so
/home/administrator/mgsvn/Common/Geometry/.libs/libMgGeometry.so
/home/administrator/mgsvn/Common/PlatformBase/.libs/libMgPlatformBase.so
/home/administrator/mgsvn/Common/MdfModel/.libs/libMgMdfModel.so
/home/administrator/mgsvn/Common/MdfParser/.libs/libMgMdfParser.so
/home/administrator/mgsvn/Web/src/HttpHandler/.libs/libMgHttpHandler.so
-Wl,--rpath -Wl,/usr/local/mapguideopensource/lib -Wl,--rpath
-Wl,/usr/local/mapguideopensource/webserverextensions/lib
/usr/bin/ld: warning: liblib_json.so, needed by
/home/administrator/mgsvn/Web/src/HttpHandler/.libs/libMgHttpHandler.so,
not found (try using -rpath or -rpath-link)
/home/administrator/mgsvn/Web/src/HttpHandler/.libs/libMgHttpHandler.so:
undefined reference to `Json::Value::Value(bool)'
undefined reference to `Json::Value::Value(Json::StaticString const&)'
undefined reference to `Json::Value::resize(int)'
undefined reference to `Json::Value::operator[](Json::StaticString
const&)'
undefined reference to `Json::Value::~Value()'
undefined reference to `Json::Value::operator[](int)'
undefined reference to `Json::Value::Value(std::basic_string<char,
std::char_traits<char>, std::allocator<char> > const&)'
undefined reference to `Json::FastWriter::write(Json::Value const&)'
undefined reference to `Json::Value::Value(Json::Value const&)'
undefined reference to `Json::Value::operator=(Json::Value const&)'
undefined reference to `Json::Value::append(Json::Value const&)'
undefined reference to `Json::Value::Value(Json::ValueType)'
undefined reference to `Json::Writer::~Writer()'
undefined reference to `Json::FastWriter::FastWriter()'
undefined reference to `Json::Value::operator[](std::basic_string<char,
undefined reference to `vtable for Json::FastWriter'
collect2: ld returned 1 exit status
make[3]: *** [mapagent] Error 1
make[3]: Leaving directory `/home/administrator/mgsvn/Web/src/CgiAgent'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/administrator/mgsvn/Web/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/administrator/mgsvn/Web'
make: *** [all-recursive] Error 1
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/347>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
