[mapguide-trac] #349: Prompt text in search commands can't include line breaks.
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 29 05:25:24 EST 2007
   Reporter:  mbeckman     |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:
  Component:  AJAX Viewer  |     Version:
   Severity:  minor        |    Keywords:
External_id:               |
 If the user inserts a line break in the prompt text in a search command a
 java script error will prevent the ajaxviewer from loading.
 Example:[[BR]]
 This text will work:[[BR]]
 "Search for places beginning with: Example 'holly' will return
 'hollywood'"[[BR]]
 This text will not work:[[BR]]
 "Search for places beginning with:[[BR]]
 Example 'holly' will return 'hollywood'"
 This could be fixed by replacing the new line characters with a html new
 line tag, so the this text would work:[[BR]]
 "Search for places beginning with:<br>Example 'holly' will return
 'hollywood'"
 To make sure there are no line breaks in the prompt text a quick solution
 for the phpviewer would be to change line 229 from[[BR]]
 StrEscape($cmd->GetPrompt()),[[BR]]
 to[[BR]]
 str_replace("\n", "<br>", StrEscape($cmd->GetPrompt())),
 Note: This also happens for the DWF viewer, but it is fixed with the same
 code.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/349>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
