[mapguide-trac] #525: Incorrect error message when logging in to
MapAdmin when server is not running
trac_mapguide at osgeo.org
Tue Apr 1 13:49:22 EDT 2008
#525: Incorrect error message when logging in to MapAdmin when server is not
running
Reporter: brucedechant | Owner:
Type: defect | Status: new
Priority: low | Milestone: 2.1
Component: Map Admin | Version: 2.0.0
Severity: minor | Keywords:
External_id: |
If the MapGuide server is not running and you try to login using the
MapAdmin you get the following error even if your credentials are valid:
"Authentication failed. Please enter a valid username and password.";
The error message returned should be what the actual failure was. In this
case it really is a MgConnectionFailedException.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/525>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
