[mapguide-trac] #520: Out of memory. bad allocation Errors
using Tiled Map
trac_mapguide at osgeo.org
Tue Apr 1 19:36:33 EDT 2008
#520: Out of memory. bad allocation Errors using Tiled Map
Reporter: zspitzer | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Tile Service | Version: 2.0.0
Severity: major | Resolution:
Keywords: | External_id:
Comment (by trevorwekel):
Hi Zac,
Which build of MapGuide are you using? Does your map have SDF layers
only? Would you be able to provide an mgp package for the defect?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/520#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
