[mapguide-trac] #520: Out of memory. bad allocation Errors
using Tiled Map
trac_mapguide at osgeo.org
Tue Apr 1 20:49:47 EDT 2008
#520: Out of memory. bad allocation Errors using Tiled Map
Reporter: zspitzer | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Tile Service | Version: 2.0.0
Severity: major | Resolution:
Keywords: | External_id:
Comment (by zspitzer):
the map is using purely SDF layers using mg 2.00 on w2k3, I'll try and
create a sample mgp to reproduce it.
i have been running the server interactively of late, i'm not sure if it's
directly related but i found this on the console this morning
(6544) Out of memory.
bad allocation
Exception occurred in method MgServerSelectFeatures.SelectFeatures at line
249 i
n file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\s
rc\services\feature\ServerSelectFeatures.cpp
(8140) Out of memory.
bad allocation
249 i
n file
kgefec: fatal error 0
kgepop: no error frame to pop to for error 21503
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/520#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
