[mapguide-trac] #524: MG 2.0 BUG...after GetSelectionXML
MapGuide Open Source trac_mapguide at osgeo.org
Wed Apr 2 12:58:11 EDT 2008
 Reporter:  macieksk                   |         Owner:
     Type:  defect                     |        Status:  new
 Priority:  high                       |     Milestone:
Component:  General                    |       Version:  2.0.0
 Severity:  major                      |    Resolution:
 Keywords:  getselection setselection  |   External_id:
Comment (by macieksk2):
 I am also seeing a problem with the GetSelectionXML function. After I use
 it
 the resource remains locked and I cannot perform any further actions
 against
 until I logout and log back into the application.
 I can normally select the feature and then delete or update it but since
 updating to mgos2 I am getting this error:
 Error: Please try your operation later as the resource was busy:
 Library://AEMSDB/Actions/487/Data/11504.FeatureSource
  StackTrace:
   - MgFeatureServiceHandler.ProcessOperation line 83 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
   - MgOpUpdateFeatures.Execute line 111 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\OpUpdateFeatures.cpp
   - MgServerUpdateFeatures.UpdateFeatures line 131 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerUpdateFeatures.cpp
   - MgFdoConnectionManager.RemoveCachedFdoConnection line 1006 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\common\manager\FdoConnectionManager.cpp
 I thought that I may have left a feature reader open somewhere but this is
 definately not the case.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/524#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
